If Alpha is 0, then do not have a way to access the origin rgb values.
Anyone knows what can I do to use VEX get rgba without pre multiply alpha. Thanks a lot.
"texture" function not support do not pre multiply alpha
2358 3 0-
- Bytedance
- 8223 posts
- mestela
- 1868 posts
I found this with PNG. Support told me to set an envvar to tell it to not automatically premult:
The other way is to load the image through cops, set the premult/unpremult on the file cop, and reference the image into your vex wrangle via the op: syntax.
export OPENIMAGEIO_IMAGECACHE_OPTIONS=unassociatedalpha=1.max_memory_MB=8192
- TaoChen
- 3 posts
mestela
I found this with PNG. Support told me to set an envvar to tell it to not automatically premult:export OPENIMAGEIO_IMAGECACHE_OPTIONS=unassociatedalpha=1.max_memory_MB=8192
Hellow, Where is this added to?
I added Variables, it didn't work.
