On capturing a close models
   1241   3   2
Is there a better way to Capture each model as close and overlapping as in the image?
Each has a name attribute (variant) so I think that could be used.
I’d like to ask you for your help
(only 4 models as an example, but there will be more in a production environment.)
Edited by Y_San - 2024年6月24日 04:56:13
capture_nearthings.hip (349.9 KB)
Here's an option to get cleaner captures in this process:
- for geometry to be captured, promote the variant attribute to prims
- loop over that geometry, using the primitive variant attribute to split pieces
- within the loop: set a point group on your skeleton based on the current variant attribute, then limit the joint capture proximity to only capture with that group
Updated HIP attached.
capture_nearthings_forloopbyvariant.hip (363.6 KB)
https://www.noad.co [www.noad.co]
オンライン
I think that's the way I'd do it as well because the skinning tools only assume single connected pieces of geometry at a time.
danfitz82
edward
Thank you very much!
It is exactly what I wanted.
All I had to do was combine for each and group!
