-I am looking for an easy way to rotate a particle locally in VOPS. In Softimage there is a compound called "Transform Local" that allows all local transforms.
- Softimage also has a "Rotate Vector" node that allows you to rotate a particle around a vector, which really just moves the particle to the rotated position but keeps the particles orientation. I am also wondering if Houdini has a simple solution for that.
thanks
Local Particle Rotation (VOPS Please)
1271 3 0-
- jamination
- 14 posts
- オンライン
- cncverkstad
- 177 posts
- cncverkstad
- 177 posts
- 9500 posts
jaminationit really depends on how you are representing rotation on particle, whether, v@v and v@up, v@N and v@up, p@orient, or 3@transform
in case of quaternion p@orient you can use Quaternion Multiply VOP, qmultiply() in VEX to rotate quaternion B by quaternion A, so B is the local one
in case of 3@transform, you can directly use Multiply VOP, * in VEX, to rotate matrix A by matrix B, in which case A is the local one
jaminationagain, just multiply your vector by matrix using Multiply VOP or by quaternion using Rotate By Quaternion VOP ( qrotate() in VEX )
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
