Sink flip particles dymamically
1423 4 1-
- mzigaib
- 1039 posts
I am using FLIP SOP and a flip boundary SOP to source a sphere with a mask point attribute noise with values between 0-1 sourcing on the first frame, as I start the sim this mask attribute get stick to the particles and I want to remove particles with values bellow 0.5 at certain frame dynamically, how can I do that with this workflow?
- 9454 posts
- mzigaib
- 1039 posts
- 9454 posts
mzigaibPOP Kill will not work directly, since POP Solver that's inside of FLIP Solver has Reap Particles unchecked, so it doesn't remove @dead particles
I tried with a pop kill but no success
mzigaibduring the simulation you can just delete the particles as the surface is generated from them
seems in order to make wholes on the fluid surface I think you need some kind of volume operation but I do not know how to do it inside the flip SOP, am I wrong?
however if you want to do it on the source before sourcing then yes, FLIP Solver SOP uses volume sources
Edited by tamte - 2025年2月11日 00:56:16
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- mzigaib
- 1039 posts
