I want to have a path animation first, then add some animation onto it.So in sceneanimate2 node,I add an animation Layer,and Clip name on sceneaddanimation I set to "anim1".Here's the problem.I would change path(curve) during keying,but animation is not updated when I modify the path,I found if I change Clip Name on sceneaddanimation("anim2") ,the path animation update.In rig tree there is "anim1" "anim2".But in my new animation Layer,I can't modify my animation curve,it says:
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.587/packages/apex/viewer_states\apexanimate.py", line 1540, in _handleFinishedChannelsChanged
self._handleChannelsChanged(channel_names, collection_name, True)
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.587/packages/apex/viewer_states\apexanimate.py", line 1555, in _handleChannelsChanged
if geo.isReadOnly():
AttributeError: 'NoneType' object has no attribute 'isReadOnly'
BaseLayer is ok,but new layer fails.
Any Help please
apex animation,error when add layer to add animation
1406 1 1-
- GreenPitaya
- 44 posts
- edward
- 8114 posts
