Does the cops hextile node have size restrictions?
   695   2   1
Hi I'm playing around with cops, creating textures for a large scene.
I want to use the hextile node in this process, but it seems to only give me a 1k output. Everything else in the cops setup is 2k or whatever else I want it to be, but even if I input a 2k uv texture into the texture coordinate input of the hextile node it still gives me a 1k resolution. What can cause this? Is it a limiation of the node?
I also wonder if there is a limit to the scale factor? As I scale up I get more hex copies, but it seems to stall at some point. As if it will only scale so far... Do you know if there is a limit in terms of scaling?
Thanks,
Dag
If you're on Apprentice, there may be a size limit. Not sure.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
@Enivob
I'm using Houdini Indie.
