Airflow (trails) from Embergen file. Is it possible?
   2186   13   1
Hi, I am trying to simulate a visualisation that portrays Airflow within a building as if it were trails:
I am planning to use Embergen and then export the ABC file to Houdini. I wonder how difficult this is for a beginner? I imagine it is possible, since I still haven't found anything Houdini isn't feasible for.
What do you recommend for a beginner?
Thank you
you have file on qiita web plats , just search on Google "Qiita Advent Houdini 2020" 0r 2021
have Fun.
Conservation of Momentum
cncverkstad
I am not sure I am following:
You can achieve this entirely in Houdini, either by using its pyro/smoke solvers for more physically based results, or by building a simplified setup with the Linear Solver to generate plausible flow around the buildings.
animatrix_
Hi. I downloaded a ABC embergen from the library.
Here is the link https://jangafx.com/software/embergen/download/free-vdb-animations [jangafx.com]
Any of those will help as a reference.
So I am not looking to sim in Houdini. Just to achieve the trails of the sim to convert them to curves.
Thank you
I started doing this:
I checked that there is a volume to the trail node. Is it possible that the Alembic is missing the Vel attribute, which is needed to trace the lines?
Thank you
Edited by zooropa - 2025年8月27日 13:52:00
I checked one of the caches and it doesn’t include a velocity field. You can approximate velocity by using Volume Optical Flow SOP between two consecutive caches.
animatrix_
Thanks a lot for this. Is it possible to share the scene? Since I am new doing this I am trying to understand the use of the timeshift. Also what do you call cashe sice I do not see the nodes applied in the screen grab.
Thanks again!
I am trying to replicate your setup.
But I am clearly missing something to get the trails. How did you generate the vel attribute?
Thank you
Edited by zooropa - 2025年8月27日 15:46:35
Here is the scene.
embergen.hipnc (89.0 KB)
animatrix_
Here is the scene.
Hi. Thank you for this. I think I have a bit better understanding now. But lines seem not to be coinciding with the smoke shapewise.
Is this something expected? Thank you
Edited by zooropa - 2025年8月28日 08:18:30
Unfortunately without the original velocity field, there isn't much you can do.
animatrix_
Unfortunately, without the original velocity field, there isn't much you can do.
Ah, I did not know that was needed to align them. I will check if it's an attribute that can be exported from Embergen.
Thank you
on qiita web plats advent Houdini 2020 , user @shin_t_o_
file "city wind generator" . 2d 3d SIM.
Find user and check Link to the Github
Edited by cncverkstad - 2025年8月29日 00:21:53
