Strange error on startup
   2531   6   0
I'm getting this error every time I start up houdini: "Magic Bullet Looks did not initialize successfully."
but does houdini even use Magic Bullet Looks?
I tried uninstalling the Red Giant plugins I have installed but it doesnt seem to make a difference
Once I close the dialog box houdini loads up fine, but its a bit of a pain to do that every time!
Houdini 21.0.440 on windows11
Edited by lricho - 2025年9月3日 01:09:07
Thanks! Clearing out the maxon plugins then giving a reboot helped. Didn't have to reinstall houdini, thankfully.
Is there any cleaner way to do this, another user of the same machine needs those plugins for After Effects, so I can't just remove it.
lricho
Was there a deleted message? Having the same issue over here
Everytime i open up Houdini 21 it shows a pop up saying "magic bullet looks did not initialize successfully"
Any fix would be much appreciated pls
I have the same problem. How did u fix it?
Set the HOUDINI_DISABLE_OPENFX_DEFAULT_PATHenvironment variable to 1.
