Recipes vs Network box
710 9 1-
- tupapioso
- 8 posts
I have a simple node setup. I select both nodes and right click. The recipe menu appears as expected. If I use a network box around the nodes and then select all, the right click doesn't show the recipe menu as before so I can't save as a recipe. According to the documentation, network boxes are supposed to be included unless explicitly excluded from the save recipe menu. Am I missing something here?
Edited by tupapioso - 2025年9月30日 20:40:47
- AslakKS
- 280 posts
- tupapioso
- 8 posts
- AslakKS
- 280 posts
- tupapioso
- 8 posts
- tupapioso
- 8 posts
I did some testing and found out that my first attempts to create a recipe inadvertently included a sticky note, which caused the error. So, I can create a recipe that includes a network box, but if there is a sticky note in the box, the following error pops up:
It would be nice if that was not the case because I want to use sticky notes to explain the use of the recipe.
- AslakKS
- 280 posts
- Mike_A
- 382 posts
- AslakKS
- 280 posts
- tupapioso
- 8 posts
