Recipes vs Network box
   679   9   1
I have a simple node setup. I select both nodes and right click. The recipe menu appears as expected. If I use a network box around the nodes and then select all, the right click doesn't show the recipe menu as before so I can't save as a recipe. According to the documentation, network boxes are supposed to be included unless explicitly excluded from the save recipe menu. Am I missing something here?
Edited by tupapioso - 2025年9月30日 20:40:47
Looks like you just need to right-click one of the nodes instead, as the network box does not have the same menu available.
Hmm. When I select all three and and then right click over one of the nodes, I get the menu and when I select the option to create a tool I get an error
Edited by tupapioso - 2025年10月1日 10:39:27
Screenshot from 2025-10-01 08-38-12.png (21.3 KB)
Works here - in 21.0.490
Edited by AslakKS - 2025年10月1日 11:44:32
Thanks. I wonder if I need to re-install or something. :o
I did some testing and found out that my first attempts to create a recipe inadvertently included a sticky note, which caused the error. So, I can create a recipe that includes a network box, but if there is a sticky note in the box, the following error pops up:
It would be nice if that was not the case because I want to use sticky notes to explain the use of the recipe.
You should submit this as a bug [www.sidefx.com].
オンライン
Fixed in version 21.0.490 I believe.
Indeed, works well in 21.0.491
Thanks. I will update my version.
