set pivot on tumble bug
   1243   3   0
just updated from 20.5.62x to 684 and set pivot on tumble doesnt work anymore
anyone else having this issue? driving me nuts...
either a bug or i pressed the wrong key at some point but i see it is set so...
Edited by staicu.teodor.23 - 2025年8月29日 14:33:03
ok, i reinstalled 4 different versions (also switched from py to qt) and i still have this issue
the mouse behavior when i click and rotate is that the pivot for rotation is set at the cameras position so basically the camera rotates in place not around the point i'm clicking
pls send help
Edited by staicu.teodor.23 - 2025年9月5日 11:38:59
I'm not sure if this is the exact same issue, but I've occasionally found the tumble to be working in a way I don't expect, and space+g seems to correct it for me.
i moved to 20.5.613 py version since to be able to work, still dont know what could be causing it on those other versions
