best way to "lock" an arbitrary curve to the origin?
   593   2   1
Hello. I'm wondering about if there is a quick, robust and procedural way to take any arbitrary curve in space that has at least normals and up vector and based on that curve's first or last point, first move it to the origin and then rotate it so that the normal will point straight down the z-axis (the N of the first/last pt)? Alternatively use the orient attribute to do the rotation if available?
please see the attached image
thanks,
Dag
Edited by Dougie0047 - 2025年11月18日 06:10:34
Hi!
I usually use matrices to do this sort of thing. You already have 2 axis, you just need to create one more with a cross product. In a Detail Wrangle I used:
vector y = point(0, "up", 0);
vector z = point(0, "N", 0);
vector x = normalize(cross(z, y)); // getting the perpendicular vector
vector pos = point(0, "P", 0);
matrix m = set(x, y, z, pos);
setcomp(m, 0, 0, 3); // Making sur the last column has zeros
setcomp(m, 0, 1, 3); //
setcomp(m, 0, 2, 3); //
4@m = m;
...right after the wrangle, you place a "Transform_by_Attribute" sop with "m". Make sur you activate the "Invert Transform".
Edited by olivierth - 2025年11月18日 09:08:06
Thanks for your reply oliverth! Transformbyattrib.. Interesting. I was not aware of this node
I'll try this out.
Thanks again.
Dag
