Assign iteration in a loop as attribute
   534   2   1
Hi there,
I want to procedurally model dice, with the text or pips as actual geometry on the faces. In a loop, I generate the numbers based on iterations and try to set i@face to match the iteration number, but I can’t make it work. The manual method works, but it's well… manual.
So if somebody has a small hint, that would be great.
Kind regards,
Christian
Update:
I made it work by switching from the Attribute Wrangle to an Attribute Create that happily accepted the iteration attribute.
Edited by Schmauch - 2025年11月20日 16:56:57
RD_Face_Orientation.hipnc (298.3 KB)
your path in
i@face = detail("../foreach_begin", "iteration", 0) + 1;
is invalid to begin with, since the node holding the iteration metadata is called foreach_begin1
but even if it was valid, detail() VEX function expects geometry, so either input number, file path or op: string pointing to sop node
since you want to directly point to sop node you need to specify it as
i@face = detail("op:../foreach_begin1", "iteration", 0) + 1;
but it may be just easier to connect foreach_begin1 to 2nd input of wrangle and do:
i@face = detail(1, "iteration", 0) + 1;
Edited by tamte - 2025年11月20日 17:16:47
CG Supervisor
Framestore, NY
Thank you for the clarification, it works with the wrangle now as expected. Using the second input.. who could have thought of that Thanks again for helping out.
