How to add a user defined MaterialX compound in Solaris?
   516   3   1
I created a MaterialX compound node as blabla.mtlx file. Now I want to use it in Houdini. In Maya I can simply use the MATERIALX_SEARCH_PATH env variable and I can use my node. In houdini the node is not visible at all. How can I use my own nodes in Houdini Solaris?
オンライン
I found this in Sidefx's doc. There's a tool to convert the materialx file into a hda.
https://www.sidefx.com/docs/houdini/solaris/kug/materials.html#custom [www.sidefx.com]
That .mtlx source file is then post-processed by two other tools:
$HHP/mtlx2karma.py - outputs the karmaNodeGraph.json file necessary for Karma to render these shaders correctly; this should be added to HOUDINI_PATH or user preferences directory
$HHP/mtlx2hda.py - produces the user-facing output HDA, should be added to any otls folder on HOUDINI_PATH or user preferences directory
MotionCOPs toolkit - pushing COPS into motion design and dynamic effects territory.
https://github.com/Boning1011/motion-cops [github.com]
A reference node with edit material should do the trick
Ah, I think the sidefx docs will help a lot. Thanks a lot.
A reference node can help but I'd prefer to have a similiar workflow as in maya where I can simply add a mtlx compound node and add to the mtx seachpath. Then I can use it alongside with the standard mtl nodes in the shader setup.
