How to use divergence on pyro cops?
   494   5   1
What is the proper way to use the divergence field inside the Pyro COPS workflow?
If I try to plug anything on the divergence output nothing happens.
Any tips?
Edited by mzigaib - 2026年3月20日 18:18:22
I mean this input here.
Edited by mzigaib - 2026年3月21日 01:35:43
No tips?
I am trying this, divergence does not affect anything.
Edited by mzigaib - 2026年4月2日 11:23:50
It does work, maybe bump up the values a bit to see
your setup applies divergence only in source area, but you can also test on different setups, like a simple setup where you feed the simulated temperature (scaled as needed) to divergence to get it expanding in hot areas etc...
CG Supervisor
Framestore, NY
You are absolutely right! The thing is that I was expecting that it would work exactly like pyro SOP which I use all the time but in this case I forgot to increase the divergence value a bit.
Thanks for the help.
