Hi!
I'm using the wParallax osl shader to fake 3D rooms inside of buildings. When I import the building with an alembic sop and apply the shader, it all works. If I unpack, or even re-pack the building, the wParallax shader only looks good when my camera faces the world negative Z direction. in any other direction, It becomes mostly black.
I noticed the primitive intrinsic packedlocaltranform on the alembic sop has lots of different values. When I unpack and re-pack, all values are set to the default matrix values.
So, I wanted change those values to what they were before but it's greyed out (meaning I cant change it).
What to do?
Modify packedlocaltransform (prim intrinsic) ?
1178 1 0-
- olivierth
- 1233 posts
- Heileif
- 315 posts
You can set it with vex using setprimintrinsic.
If you search setprimintrinsic in Google AI-mode, you get a example code of how it works.
You maybe need to do a inverse transform of the points first tough before the repack, or you get a double transform.
Probably a better way to do it. The inverse part can be annoying.
