Running houdini at home on a laptop with Vista I get this random problem where Houdini 9.0.xxx refuses to start. hmaster.exe just crashes before even the splash screen has appeared. If it happens no amount of retries will get it to open but rebooting and trying again seems to fix it. H8.2.xx will start every time no trouble even after H9 has refused.
Anyone else seen this? Its hard to report as its so random and occasional.
Houdini on Vista
9616 14 2- Simon
- 2199 posts
- jason_iversen
- 12501 posts
Yes! I get this. The hamster dies (hmaster, really) immediately upon trying to start any of the 3D apps. It starts Mplay and Hkey fine.
Windows Vista 32bit
on a Dell Inspiron 9200 (ATi Radeon Mobility 9700)
Catalyst drivers around May this year:
- Driver Packaging Version 8.36-070314a3-045540C-Dell
- Provider ATI Technologies Inc.
- 2D Driver Version 7.01.01.622
- Direct3D Version 7.14.10.0489
- OpenGL Version 6.14.10.6465
- Catalyst® Control Center Version 2007.0322.2238.38535
Windows Vista 32bit
- aliax
- 58 posts
- Simon
- 2199 posts
- andrewlowell
- 537 posts
well, I got vista a few months ago because I needed something that would keep up with sound cards / audio software etc and also do 64-bit. I've discovered that just about everything I've tried to run on it, even start up and shut down is slower / much slower.
The only thing that runs faster is the actual applications which allocate 64 bit, and use all the memory, once they are running anyway.
So, I'm switching to linux-64 and I've been plesantly suprised by how far the audio software and hardware has come since I last checked.
Anyone have any recs on video editing software for linux?
H8 seemed to work fine though although 3ds max crashes a lot more (ironic since it's made for windows), been too scared to try H9
- edward
- 7735 posts
Actually, the 64-bit builds of Houdini should have more usable crashlogs. It would help if these were sent in if anyone could try out Vista 64-bit. (Keyframe?)
FWIW, I run a Vista 32-bit desktop at home and don't seem to have any problems. Mind you, I don't really push Houdini through its paces though.
- jason_iversen
- 12501 posts
I think in my case it might've been the driver. It used to work with the driver that comes with the installation disks. The official Dell-sanctioned Catalyst driver might have been the thing that screwed it. I don't know. Or a Windows Update that probably happened in past few weeks broke it.
- Simon
- 2199 posts
edward
The only paces I've put it through are opening it and looking at new stuff in the help…. I really haven't done anything serious with it at all yet…
I suspect drivers too, since that's what it always is, but I've got it running nicely with H8 so until I'm ready to bin H8 I don't want to mess with them.
- romarier
- jason_iversen
- 12501 posts
I mucked with my Ati drivers, trying to roll back and forward and installing whatever I could find on guru3d.com and I ended up back where I started - on driver 8.360.00 and it was crashing. I left it alone for a few days in total resignation but I just tried it now and it worked!
For some reason it insisted on spending a minute running hsvg.exe but it pulled through. I have no UISCALE or Preference set, so I was surprised to see hsvg.exe running, but it works now.
9.0.750.
9.0.750.
- Simon
- 2199 posts
- anakin78z
- 80 posts
- Carlos
- 104 posts
- lesath
- 19 posts
- Simon
- 2199 posts
