how can i find the name of attribute i require
   3143   2   1
for example the attri_shader is vm_surface
and there is an attribute for dop_cloth is pointoanimation
how can i find the name of attribute i require(ALL—-some of them can't find in the node help?)
or any rules to name it by ourself ?
is there any explain in the help?
thank you!!
Edited by - 2009年8月12日 05:05:31
https://vimeo.com/user3971456/videos [vimeo.com]
Check the helpcards by pressing :?: on the parameter tab. You can see a section called “Local variables”. There's also a good tutorial here:
http://www.sidefx.com/index.php?option=com_content&task=view&id=1500&Itemid=132 [sidefx.com]
Jobless
attributes and local variables are not the same thing.
one way to find attributes of a node is from the Python shell.
e.g.
node = hou.node(path_to_node)
then start typing
node.parm(
you should see a list of the attributes for that node.
