I'm trying to use the python noise function.
hou.hmath.noise1d(hou.Vector3(1.0,1.0,1.0))
but it returns 0.5 no matter the input. Am I doing something wrong?
hou.hmath.noise1d returns 0.5
5000 5 1- burnie
- 23 posts
- Anonymous
- 678 posts
- burnie
- 23 posts
I know how a noise-function works. The whole idea is to get the same “random” number every time at a certain position.
The problem is
hou.hmath.noise1d(hou.Vector3(1.0,1.0,5.0))
hou.hmath.noise1d(hou.Vector3(2.0,1.0,2.0))
hou.hmath.noise1d(hou.Vector3(4.0,1.0,1.0))
all return 0.5
is this function not implemented yet?
The problem is
all return 0.5
- symek
- 1390 posts
burnie
The problem is
all return 0.5
Try hou.hmath.noise1d(hou.Vector3(1.01,1.01,5.01))
There must be reason for that, noise function in hscript behaves the same way. Don't ask me why
skk.
- johner
- 817 posts
SYmek
The results of “exhelp noise” do a pretty good job of explaining Perlin noise:
The noise is calculated on a unit-spaced lattice and then internal
points are interpolated from lattice points. This means the noise
will be independent between points one unit distance apart. You can
scale the inputs to achieve different frequencies.
Basically this means that the noise will always be zero at integer values and smoothly varying in-between. Noise1d is just shifted so that 0.5 is the median value.
Here is a CHOPs graph of 1D noise vs time. It always crosses 0.5 at integer time values:
- burnie
- 23 posts
