the wood and stone patterns in the new H11 materials seem not to be attached to the geometry position. Instead they seem to be attached to the camera's position.
The checkerboard material e.g. looks ok.
I've attached a video with a simple camera move.
Anything I can do without diving into the SHOPs ?
Carsten
H11 wood and stone materials not attached to geometry?
5072 5 0- carstenw
- 30 posts
- 8595 posts
those are 3D procedural patterns computed by position not by uvs so if position changes they will not stick to it
all you need to do is add Rest SOP to your geometry before any deformation
this materials should use rest attribute prior to P if exists
from looking inside of them it seems that stone is ok but for wood you need to plug Rest Position VOP between GlobalP and first input of uvnoise node
- carstenw
- 30 posts
thanks! I wasn't aware of the rest SOP in this case.
I've got still one issue with the stone material, though: I just added the rest sop to a sphere, but the result looks a bit odd: Part of the surface seems to be reverted to the inside ?! Besides, I need “polygons as sub/d” to get a decent rendering.
Carsten
Carsten
- 8595 posts
- carstenw
- 30 posts
tamte
it seems that stone material is not set up correctly either
connect GlobalP to first input of displacenml node
there is restpos connected there now which is in another coord system and therefore causing problems
Yep, that solved it! Thank you very much for your help!
I suppose I should file a bug report?
Carsten
- rafal
- 1449 posts
