Export alembic with one primitive instead of many
   884   3   1
Hello, I am playing around with STT nodes and I have a noob question.
How can I export .abc in such way that I get one deformed mesh primitive instead of many primitives?
My goal is when I import to Unreal I would like to have only one mesh track for geometry cache.
I have googled around but could not find the technical solution.
Thank you.
Edited by kilian89 - 2025年4月8日 07:39:52
オンライン
add s@path attribute representing the abc hierarchy path
so in your case all primitives will have the same value for example: /fern/fernShape
and on ROP Alembic SOP make sure Build Hierarchy From Attribute is checked and Path attribute is: path, or whichever attribute contains the hierarchy
tamte
I have figured out that I can unpack instances and use polysoup node to create one prim for stem and one prim for unpacked leaves. But I am not sure if this is proper workflow.
I will try your method too. Thank you very much for help. I appreciate it.
Screenshot from 2025-04-08 16-13-18.png (1.7 MB)
オンライン
ah, yes, you have to unpack
otherwise the export will preserve packed prims as a different objects and add suffix in case of path conflict
Edited by tamte - 2025年4月8日 13:00:54
