viewport issues
   332   0   1
Is anyone else having non-stop viewport issues? I am at the point where I reset the viewport multiple times every few minutes.
1. Dopnets at obj level stop updating. Reset viewport alone doesn't fix it. I have reset viewport and delete a node in the dopnet then hit undo to bring that node back for a chance for it to work.
2. When you go into a SOP packaged solvers (vellum solver sop, pyro solver sop, etc) (and possibly just subnets in general) the simulation won't update. I have to reset viewport. I have reported that bug multiple times across multiple versions, but ever since the bug was introduced it's never been fixed 100%. Pretty sure I have had this issue since like h17 or 17.5
3. background image sequences for cameras get stuck on some frame. Have to reset viewport.
4. animated textures in solaris stop updating (in vulkan and karma) even with allow shader animation on
5. Handles tools/viewer states don't properly activate.
6. Other objects don't show when either "ghost other objects" or "show all objects" are on. Resetting viewport fixes this.
7. Viewport generally not displaying the correct data or blank, until reset.
8. Textures not properly updating, but then houdini crashes when you reload textures.
9. Random data from a simulation showing in the viewport when it shouldn't.
I will probably try to report some of these, it's just there are so many and I don't have definitive ways to reproduce some of them. Is anyone else having issues? Like I said, I am at the point where reset viewport is just part of the workflow, but I have to keep hitting. A lot of these issues have transcended houdini versions, different OS's, different drivers, etc.
Edited by evanrudefx - 2026年5月25日 11:58:23
Thanks,
Evan
