when i use “shatter” to break an object,there are groups called inside,piece0,piece1,piece2… …
then i loade it to RBDfreature the inside obj is superfluous。
if i delete the inside group ,the piece* groups are just pieces not been capped.
else if i delete nonselection such as piece0, the obj piece0 is right, but there are 2 groups in the piece0 obj(inside and piece0)
so can i delete the group “inside” attribute but keep the object?
thank you
cai i delete the "group" attribute?
7565 2 0- luoqiulin
- 303 posts
- Aearon
- 54 posts
you can use the group mask in the rbd fracture dop, e.g. put in piece* and it will only use the groups that match that pattern
about what you where doing, i think you are confusing two ideas: deleting the primitives in a group and deleting a group.
i'm guessing you use the delete sop to delete the primitives of the group, instead you should use the group sop to get rid of the group.
- luoqiulin
- 303 posts
Aearon
oh thank you i got your meaning
