I created a VEX Surface Shader Operator via File -> New Operator Type
Now I want to add the OGL SHOP Options to display texturemaps in the viewport.
I cannot add them through the Edit Parameter Interface, as the Properties are defined by the Vex Code.
If I add a #pragma rendermask OGL to my vex code I get a lonely OGL diffuse (ogl_diff) parameter added to my shader dialog.
How to add the complete OGL Folder to such a shader?
Thanks,
Georg
Add OGL options to VEX Surface Shader operator
3580 3 0- rdg
- 401 posts
- mark
- スタッフ
- 2591 posts
rdg
Thanks,
Georg
I'm not sure I understand exactly, but have a look at $HH/scripts/shop/shop_oglsurface.py.
- rdg
- 401 posts
Sorry, while making this screenshot I guess I undestood some details.
A VEX Surface Shader defines all dialogs in the code, that's why I cannot add the parameters in the ‘Edit Operator Type’ window …
Still:
A shader created with with “New Operator Type” doesn't allow to add the OGL options. Unlike the VOP SOP which has these OGL options ‘preinstalled’.
I don't want to add them via the gear, as I don't understand all this galley stuff yet.
I want a VEX Shader with code that has OPL Options … if this is possible.
But I'll check the file you mentioned and see if I can come up with something.
Still:
this is not a science fair.
- rdg
- 401 posts
