I am very new to Houdini and was doing a tutorial where a wind field is used with a fluid container.
I created a new scene, put a fluid container in and selected it. Then I clicked the wind force in the shelf, but all thet happened was an error message popping up “Attempt to access an object that no longer exists in Houdini”.
So I tried the procedure vice versa (first selecting the wind force, then the fluid container), but all I got was the same result. Looking it up in the help said that I did nothing wrong. So I created another scene, but again all I got was an error message, no wind field.
So, how do I correctly create a wind filed for a fluid container? What am I doing wrong?
Unable to set up wind force with fluid
8951 7 1- Phlok
- 85 posts
- ragupasta
- 349 posts
It works for me just fine.
Make sure you are using the wind force from the drive simulation shelf and not the drive particles shelf.
All I did was:
CTRL Click a fluid container
Click the wind force shelf tool from the drive simulation tab
Select the container
Hit enter
A wind force node is dropped in the autodop network.
All I did was:
Hit enter
- Phlok
- 85 posts
- JColdrick
- 4140 posts
- EigenAlex
- 639 posts
- klasse
- 60 posts
- Allegro
- 696 posts
- klasse
- 60 posts
