Hello world again.
From Hot key manager screen, Where should i click to set vertical, front view, rear view, top view and so on.
I see three column in the hot key manager screen.
context, action, assigned keys. i do not know what should i click to set my view port. Please help me. I am using Mac.
Setting Hot Keys
2166 2 2- aplink
- 365 posts
- stevenong
- 1631 posts
There are already hot key assigned to the Front, Right views etc. If you click on “persp1” in the viewport > Set View, you'll see the different views and each of them has a number next to it which is the hotkey.
To set a hot key for the Back View, hold down Ctrl+Alt+Shift, click on Back Viewport and the Hotkey Manager will pop up. Now, click in the first row under the Assigned Keys column, click on it again and type in the hotkey you want.
I highly recommend you go through the Basics [sidefx.com] help documents to familiarize yourself with the UI.
Cheers!
steven
Cheers!
steven
- aiworks
- 130 posts
