for example the attri_shader is vm_surface
and there is an attribute for dop_cloth is pointoanimation
how can i find the name of attribute i require(ALL—-some of them can't find in the node help?)
or any rules to name it by ourself ?
is there any explain in the help?
thank you!!
3147 2 1-
- luoqiulin
- 326 posts
- オフライン
- Soothsayer
- 875 posts
- オフライン
Check the helpcards by pressing :?: on the parameter tab. You can see a section called “Local variables”. There's also a good tutorial here:
http://www.sidefx.com/index.php?option=com_content&task=view&id=1500&Itemid=132 [sidefx.com]
Jobless
Jobless
- whalerider
- 194 posts
- オフライン
