Is it possible to render the shadow of an object but NOT the surface the shadow is being cast on?
The scene I have, has a character standing on a grid plane.
I'm trying to just render my character and his shadow so that it will look like he is standing and casting a shadow on the ground of the new footage I'm going to be comping on top of.
Rendering shadows
2428 2 2- Arrev
- 7 posts
- mrbag
- 21 posts
Check out the VEX ShadowMatte shader. Placing this on the grid in your scene and rendering the character as a phantom object you will get the shadow of the character on the grid in the alpha channel of the final image.
I have attached a demo file with take takes in it.
MAIN=>render both the character (sphere) and the grid normally.
SHADOW=>the setup as described above. Check the alpha and you should see the shadow only.
Hope this helps.
Hope this helps.
Nathan Ortiz
CG Supervisor, Framestore Melbourne
- Arrev
- 7 posts
