Hi!
Is there any method to create VECTOR attrbiutes with addAttrib function of hou.geometry() class?
according to documentation, the default value of attribute beeing created is determined by the ‘default_value’ parm. It could be an integer, float, strong, integer sequence and float sequence.
All these forms create attrbutes, which ends with digits, like at0, at1, at2 etc.
Of course I can manually create 3 attributes : atx, aty and atz, but then I'm not able to set them to be transformed as normal ….
How can I do it?
addAttrib(self, type, name, default_value, transform_as_normal=False) → hou.Attrib
transform_as_normal
This parameter is only available when the default value is a sequence of 3 floats. For such attributes, Houdini will not modify the attribute values when it transforms (translates, rotates, etc.) the geometry. If you want to the attribute to be transformed as a vector (such as a normal vector) when Houdini transforms the geometry, set this parameter to True.
Thank you
