assign rand maps to objs
   3714   4   2
i have many geos in obj level, all of them have assigned the same matterial “/shop/mantrasurface” , but for every geo i want it has a rand color map.
so is it possible to write an expression to baseColorMap just like this“$HIP/texture/map`rand($GEOID)*10`.jpg” , or any other way?
https://vimeo.com/user3971456/videos [vimeo.com]
スタッフ
You have to grab each object and in the Material tab, reference your material.
Grab and create the local shader parameter using the right arrow menu.
Insert your expression in there. You can use the opdigits(“.”) expression feeding as the seed to rand for the texture map lookup:
butterfly`floor(fit01(rand(opdigits(“.”)) , 1, 7))`.pic
See the attached example file.
object_rand_texmaps.hip (1.2 MB)
jeff
jeff thank you very much , is your right arrow menu means “editing parameters interface” ? when i create parameters from nodes it tells me: “node is outside subnet…”!
so should i create this parameter By Type manually?
luoqiulin
jeff
He means on the material tab of your geometry object.
Screenshot-Untitled Window-1.png (147.1 KB)
Drive, monkey, drive!
oh my god
thank you
