constant smoke from fast moving source
   6549   6   1
Hello guys. I have this sphere that moves very quickly as a source for my fluids and therefore leaves a stepping trial of smoke where it should be constant.
On the pyrosolver node (wispy smoke preset), I raised the max substeps to 10 but I get the same result as if it was set to 1.
Any help would be very appreciated. Thank you in advance
Luis Alberto Cayo
freelance VFX artist
www.lacluna.com
If you are using $F for your animation switch to $FF, otherwise substeps wont work.
Drive, monkey, drive!
thank you for your reply. where should I change that? in the file node of my cache?
Luis Alberto Cayo
www.lacluna.com
You should change it where you do your animation of your emitter.
I am animating a sphere with a couple of transform nodes. I keyed the values, nowhere I use nor see a $F.
Luis Alberto Cayo
www.lacluna.com
Did a quick test. I fixed it here by adjusting Sub Steps on the AutoDopNetwork.
yes, that works! thank you very much
Luis Alberto Cayo
www.lacluna.com
