Hi all ,
I have a string parameter with the string of “grp_letter_1” I want to replace the 1 in the string with my own float attribute called $FOO which returns 1 2 3 4 5 6 7 over $NFRAMES etc etc. Currently this fails “grp_letter_$FOO” I seem to remember this is because a string cannot return the value of a float. Can anyone point me in the right direction ?
Rob
? returning a float value in a string
6643 7 1-
- circusmonkey
- 2624 posts
- オフライン
- zarti
- 330 posts
- オフライン
- Erik_JE
- 300 posts
- オフライン
circusmonkey
Hi all ,
Rob
grp_letter_`$FOO` should work fine.
Drive, monkey, drive!
- circusmonkey
- 2624 posts
- オフライン
- circusmonkey
- 2624 posts
- オフライン
- symek
- 1390 posts
- オフライン
This is because Group parm doesn't accept local variables, since it cannot evaluate per prim/point. $F is a global variable, so it does work this way.
Anyway, this doesn't matter, because if you put $COUNTER into Filter Expression parm (Delete by Expression), you have pretty much the same setup working (though I'm not sure if this is what you wanted ultimately)
- zarti
- 330 posts
- オフライン
circusmonkey
See attached for a simple example of what I mean the delete sop takes box_`$F` in the group parm but fails with box_`$COUNTER` ! any ideas why ?
Rob
i believe `$F` works because it is a Global Expression Variable .
`$COUNTER` doesnt work there because it is the same thing as writing `$PR` or `$PT` ( !? ) .
edit: SYmek was faster ..
except the things that cannot be seen , nothing is like it seems .
- circusmonkey
- 2624 posts
- オフライン
