Hi
I made a simple test with some liquid inside a torus shape. I extruded the torus just so slightly, so that it has a little bit of thickness and add a glass shader.
For the liquid I use a standard mantra surface shader with “Emission” turned on.
The problem I have right now is that the liquid is not illuminating the floor beneath it. When I hide the glass torus or set the opacity in the glass shader to 0, the floor gets illuminated. But of course that's not what I need. The emitted light should travel through the glass shader.
Is there a way to either modify the glass shader, so that the illumination from the liquid passes through, or is there a setting in either the shader or render option that might help in this kind of scenario?
cheers,
Daniel
Luminous Surface not emitting light through glass
2657 2 0- schyzomaniac
- 69 posts
- tamte
- 8622 posts
- schyzomaniac
- 69 posts
