how to make a wire object act like an rbd
1539 2 2- zdimaria
- 390 posts
- edward
- 7723 posts
- old_school
- スタッフ
- 2540 posts
The wire solver solves on points and edges. Depending on the shape of your object, if it is more round it will hold up better than if it were flatter in one direction. The less the angle between edges, the stiffer the joint. The greater the angle, the less stiff the joint. Can give you what you wanted, or not.
If your object is collapsing in a way that doesn't make sense for what you want, perhaps try adding internal re-inforcement cross-bars.
Many ways to do this. I just randomly connect points and whittle away at the seed doing the random sort to see if something looks good. Actually I will whittle away at the seed if the defaults don't work as well as I would wish.
Hope this helps.
Hope this helps.
