This may seem small but….
I notice that in houdini, when you pull an output wire off a node, then press tab and choose a node type to create and auto connect, you have to then specify where to drop the node.
Although I have gotten amazingly fast, is there a workflow that allows me to quickly string together nodes without having to specify where to drop them (i.e. press enter after picking a location?). I would love to be able to simply skip the last step of specifying where to drop the node, and simply have the node drop right where my mouse was when I pressed the tab button (or if right clicking on an output plug to pick a node, it simply locate itself a few units below the node)
Has anyone come up with node dropping workflows that I am not thinking about?
been thinking about this recently....
2113 3 1- grayOlorin
- 1799 posts
- edward
- 7750 posts
- animatrix_
- 4536 posts
I submitted this on Sep 16, 2012: bug #51118 (:
I wish it worked because I would really love to skip the node placement step.
For all the most frequently used operators, I bypass the TAB menu altogether using hotkeys that immediately creates an instance at the current cursor location, and even wires if a node was selected.
I get about 60 hotkeys per context. For example for SOPs:
F - Fuse
G - Group
S - Switch
L - Line
V - VOPSOP
C - Copy
T - Transform
Saves me a great deal of time as creating nodes is one of the most frequently performed action in Houdini.
I really wish we see some enhancement in this area for H13.
F - Fuse
G - Group
S - Switch
L - Line
V - VOPSOP
C - Copy
T - Transform
- grayOlorin
- 1799 posts
