Is it true that render in Houdini takes longer than other?
2611 3 0- gohalves
- 69 posts
- zdimaria
- 390 posts
- old_school
- スタッフ
- 2540 posts
gohalves
Is it true that render in Houdini takes longer than other packages like Maya?
You can download the free apprentice on a machine with a capable graphics card and give Houdini and Mantra a whirl for yourself. We make our software readily available for both learning and testing so that you don't have to ask these kinds of generic questions but do actual hands-on testing.
It's pretty easy these days to import a scene using obj/fbx/alembic/iges and go straight to the ipr view and hit render. Houdini will place a render output node for you and use a headlight as default. Then you can go add additional lights holding down the Ctrl-key and clicking say an area light from the shelf to inherit the view.
When you are trolling the internet for advice in lieu of doing hands-on testing, always have a look at the date of the various posts when doing research on render engines. A lot can change in a few months in the render world. Looking at a post that is even a year out may be misleading. That goes for all render engines.
Very glad you asked the question btw.
- anon_user_37409885
- 4189 posts
Mantra is excellent! Grab the apprentice download, have a play and there are good rendering tips when you need:
http://www.sidefx.com/docs/houdini12.5/render/tips [sidefx.com]
