Hi!
When exporting geometry with changing topology through Alembic the geometry is exported fine, but the groups that I created (and change accordingly in houdini) are not exported correctly.
Does alembic only support static facesets? or is this some kind of bug that I should send a report?
I attached a simple scene file to demonstrate the error.
Houdini dynamic groups to Alembic Facesets problems
2906 3 1- robonilla
- 84 posts
- mark
- スタッフ
- 2593 posts
robonilla
Hi!
This is a bug – but I'm not sure exactly where the bug is right now. The issue is that the frames-per-second is not being applied when loading the face set geometry. This means that the face sets aren't synchronized with the rest of the geometry.
- mark
- スタッフ
- 2593 posts
robonilla
Hi!
The bug was in export of animated face sets from Houdini. This will be fixed in the next daily build.
- robonilla
- 84 posts
