Hi, i recently upgraded to H13 and every time i put skylight from shelf into the scene H13 freezes. During freeze up task manager shows houdini keep using more and more ram untill it maxes out and crashes. I did not have this problem with H12.5
Im using nvidia gtx 680 with 331.65 drivers on windows 7
Every other light sorce works fine except skylight. I also tried beta version of H13 it has the same problem.
Thanks in advance.
H13 Skylight crash
2561 3 0- AntonCromas
- 19 posts
- anon_user_37409885
- 4189 posts
- chrism
- スタッフ
- 2494 posts
- AntonCromas
- 19 posts
MartybNz
try turning off GPU acceleration for compositing in the preferences.
Thank you that did work and I submitted the bug report. The problem only occurs it GPU accel enabled when the houdini loads up, if it was disabled and then re-enabled the problem disappears for that session till next restart.
But keeping it off completely solved it for me, thanks again; I dont know why I didnt try deleting H13 config folder to begin with. ops:
