I brought an .obj in from Sculptris, cleaned up some garbage and repositioned it. I reset the transforms in Pre-Transform so everything was at 0,0,0 and then saved it as a .bgeo via right-click “Save Geometry…”
All fine and dandy, except when I import the bgeo file, it's in exactly the same place as it was before repositioning.
Is there a way to truly delete the initial transform values?
If not, can I force it to save using current transforms?
Or did I just miss a step somewhere?
Thanks,
M.
