Hi
I would like to know when creating interface for a digital asset, how I can define a file pattern in File parameters for “folders” or “directories”; So that when the user is going to choose a file, when inside a folder and clicks Accept, it DOES accept the folder and doesn't need to click on a file.
Edit Parameter Interface: file pattern for directories
5683 3 2- Seiffouri
- 41 posts
- Sadjad Rabiee
- 1391 posts
But if you create a File parameter and Select only one Folder (Don't move inside folder) and Press Accept ,You will take just Folder path :?
However If you wanna select a File ,But Houdini put only Folder path in the parameter ,I think you should use Python Script :idea:
Write a simple python script to for extracting folder(directory) path from full file path ,then use this script in the “Callback Script” in the “Type Properties” window
*** Create hdaModule and call it in the “Callback Script” from File Parameter ***
Check Attached FIle :wink:
- Akelian
- 34 posts
- tamte
- 8554 posts
