Where is SSS Scatter Sop? I can't find.
http://www.sidefx.com/docs/houdini13.0/nodes/sop/sssscatter [sidefx.com]
2340 1 1-
- jerry7
- 681 posts
- オフライン
- Sadjad Rabiee
- 1391 posts
- オフライン
SSS Scatter SOP doesn't need in the currently Houdini version , You can use Mantra Surface shader directly for computing SSS .
So this node is hidden right now and if you wanna use this node , you can unhide this node via this command :
To see all of the hidden nodes execute this command in the Textport :
opunhide
And to unhide SSS Scatter use this command :
opunhide Sop sssscatter
:wink:
opunhide
:wink:
