Particles in Primitive Sop
   3530   4   0
I noticed there are Particle Type options in Primitive Sop. It seemed particle can be rendered as Sphere, Lines ,Tube and so on. I connected it to particle Dop Import, but no effect. How to use them?
http://www.sidefx.com/docs/houdini13.0/nodes/sop/primitive [sidefx.com]
you need to create particle system primitive that contains your points
use Add SOP/Particles Tab/Add Particle System
then Primitive SOP/Particles Tab will set the data on this particle system primitive
thanks very much!
I tested and meet a new problem ,the Add Sop/Paritcles Tab/Particle Group has no effect with different stream. I don't know why?
particle primitive.hipnc (208.4 KB)
I solved the problem by blast non-current stream.
Could we set render type attributes in Dop Network or directly with AttribCreate ? Where can I get more detail information about Particle System Primitive in help document?
