Image into attributes in SOP
4626 7 2-
- 5DN
- 152 posts
- オフライン
- Andy_23
- 919 posts
- オフライン
- 5DN
- 152 posts
- オフライン
- circusmonkey
- 2624 posts
- オフライン
- Enivob
- 2659 posts
- オフライン
@circusmonkey: I am tying to accomplish something similar to what you have posted.
What I want for output is points on a grid only if the alpha from the image is not 0. How would I add points to a group or delete them from the grid while in VOPSOP context?
Basically knock out the alpha points only.
I modified your VOPSOP by changing the colormap to export RGBA. Then I compare the 4th value to greater than zero and route that to an attribute. One level up I have placed my new variable $MYAPLHACHAN into the Point SOP following the VOPSOP and I do get non-colored output where expected.
But how do I actually use $MYALPHACHAN to remove the points from the grid?
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- PradeepBarua
- 443 posts
- オフライン
- PradeepBarua
- 443 posts
- オフライン
- Enivob
- 2659 posts
- オフライン
Thanks for the reply, the Delete after the VOPSOP does work but I am not sure why?
What exactly is the contents of the $MYALPHACHAN?
I assume it is some kind of array of data. Wouldn't I need a For/Each sop to iterate through the data with the Delete inside?
