Bullet RBD destruction problem
   3542   4   3
I'm trying to remove constraint network's primitives in SOPsolver with attribwrangle
if (@angle > 0.00001)
removeprim(0,@primnum,0);
but it doesn't work. Any idea?
P.S. file is attached.
cross test.zip (108.9 KB)
Try changing this:
to this:
removeprim(geoself(),@primnum,0);
jparker
Try changing this:
to this:
Thanks for reply
It doesn't work I tried also with glue constraint relationship, but it just doesn't brake. I can't understand what can be a problem.
Not sure what version you built it in, but just tried with Houdini FX 14.0.244.
I had to drop down a new constraintnetwork node for the glue and cone relationships and it works fine.
AlexLombardi
Thanks a lot Alex
I installed daily build 246 and it works
