IF statement and WHILE loop in Vops
   4208   4   1
I'm trying to wrap my head around Vops IF and WHILE statements. Especially the ‘condition’ part.
Am I understanding it correctly when I say that you must reduce the condition on which these statements operate to a 0 or a 1?
So the condition must be either 0 or 1.
I CANNOT for example produce something like:
IF (POINT == 45) then execute code.
The only way I could do this is with something that looks at the numbers, and when it sees 45 it transforms it into a 1, which activates the IF statement?
So in this version it would be something like:
Value = 0.
When Point number == 45, then Value = 1
I pipe in Value into the IF statement condition and when it gets the 1, it executes the IF code.
Am I correct or am I missing something?
Edited by - 2015年2月23日 16:26:26
Winter is coming!
if (POINT == 45)?
A single = is an assigmnet operator.
Cheers
Bonsak
Edited by - 2015年2月23日 16:26:13
http://www.racecar.no [www.racecar.no]
bonsak
if (POINT == 45)…
Cheers
Bonsak
Yeah, sorry, that was an oversight I've corrected it.
Winter is coming!
That's correct, you generally use a Compare node to get the boolean. Threre are also And and OR nodes.
Jesse Erickson
Fx Animator
WDAS
tjeeds
Got it - thank you.
Winter is coming!
