I have a test scene for learning Geo Time Sample.
In this scene, there are two object. One is particle(deleted v attribute) , other is switch sop which change topology.
The two objects both are changing topology with time. But why one has motion blur and other has no?
Geo Time Samples
3841 3 1-
- jerry7
- 680 posts
- オフライン
- Sadjad Rabiee
- 1391 posts
- オフライン
In the Motion Blur operation , Houdini using floating frames , not integer frames , for examplefrom frame 1 to 2 (in geo samples 4) , Houdini do sample from frame 1 , 1.25 , 1.5 , 1.75 and frame 2 , in this case it can compute object's direction.
in the Particles , because they have floating animation between each integer frame , Houdini can compute their velocity even for 1 frame .
But in the Switch SOP method , your points changed immanently on frame 2 , (They are constant) , so the point's position for frame 1 , 1.25 , 1.5 , 1.75 are same and they change only in frame 2 , in this case Houdini can't compute Motion Blur !
- Sadjad Rabiee
- 1391 posts
- オフライン
- jerry7
- 680 posts
- オフライン
