Low polly fix?
   2702   4   1
Hey guys, I asked this in the Unreal 4 thread but I may get a better answer here.
I am generating a Lsystem and then attaching a metaball to it, I can't get it right.
I need to smooth that, this is my setup.
should be smooth by default
make sure your viewport display is set to Smooth Shaded to see that
tamte
Thanks for the reply, but when I export this to unreal I still get the square pollys… Do you know a fix?
Like tamte said, it should be smooth. When you middle-mouse-click on the convertmeta sop you see that it creates a point normal attribute N. Maybe it's a display driver related issue then ?
I just exported it as obj and got it into Unreal without any problems.
metaball_obj.zip (361.7 KB)
hou_unreal.hip (60.2 KB)
blackpixel
YOU ARE A LIFE SAVER! It was the step size the whole time You have no idea how much that helped, being able to see the hip file.
Quick question though, when I UV I get,
With these settings
UVTEST.hip (62.6 KB)
