Hi !
i'm in trouble
I get this error when i try to launch a job with
I'm using debian jessie with H14.0.444
I'm surprise because I use H14 with amazon with success for a while now
I get this error when i try to launch a job with :
could you help me ?
File “/opt/hfs14.0.444/houdini/python2.7libs/hdefereval.py”, line 114, in _processDeferred
result = code(*args, **kwargs)
File “/opt/hfs14.0.444/houdini/python2.7libs/cloud.py”, line 967, in _onShowFileReferenceDialog
num_cloud_machines, machine_type)
File “/opt/hfs14.0.444/houdini/python2.7libs/cloud.py”, line 995, in _onCloseFileReferenceDialog
if not _readAWSKey(project_parms, prompt_user=True):
File “/opt/hfs14.0.444/houdini/python2.7libs/cloud.py”, line 258, in _readAWSKey
succeeded, prompt_for_key = _readExistingAWSKey(cloud_region, prompt_user)
File “/opt/hfs14.0.444/houdini/python2.7libs/cloud.py”, line 305, in _readExistingAWSKey
access_key_id, encrypted_secret_access_key, cloud_region)
File “/opt/hfs14.0.444/houdini/python2.7libs/cloud.py”, line 345, in _promptForPassphrase
access_key_id, secret_access_key, cloud_region)
File “/opt/hfs14.0.444/houdini/python2.7libs/cloud.py”, line 130, in setAccessKeyAndGetError
File “/opt/hfs14.0.444/houdini/python2.7libs/cloud.py”, line 248, in _createRawAWSAuthConnection
server=“%s.ec2.amazonaws.com” % cloud_region)
File “/opt/hfs14.0.444/houdini/python2.7libs/EC2.py”, line 53, in __init__
self.connection = httplib.HTTPSConnection(“%s:%d” % (server, port))
AttributeError: ‘module’ object has no attribute ‘HTTPSConnection’ 8)
[SOLVED]Amazon EC2 error
2133 4 2- 7on7on
- 22 posts
- awong
- 818 posts
There's probably a problem with importing the ssl module. In the Python shell, what do you get if you run:
import ssl
It'd also be helpful to see what libraries are loaded. You can get this list by running:
print open(“/proc/self/maps”).read()
This is rather long, so maybe put them into a text file attachment.
import ssl
Andrew / アンドリュー
- 7on7on
- 22 posts
Thx to help me awong!
you right there is a probleme with my ssl module
when I type “import ss” in the houdini python shell, i get :
File “<console>”, line 1, in <module>
File “/home/colin/Softwares/gaffer-0.13.1.0-linux/lib/python2.7/ssl.py”, line 60, in <module>
import _ssl # if we can't import it, let the error propagate
ImportError: No module named _ssl
I attach to my post the outpout of the command “print open(”/proc/self/maps“).read()”
- awong
- 818 posts
- 7on7on
- 22 posts
