remove point inside if block
1968
2
1
- NAHASSIA
- 125 posts
used to remove points conditionnaly inside vops with an if then node “old school” cant find a way to do the same with the new if block workflow…?
thx for any help
- tamte
- 8621 posts
you have to pass the ptnum through block begin, then connect to remove point
so that Houdini knows that it's inside of if block
FX Supervisor
Method Studios, NY
- NAHASSIA
- 125 posts
THX
it's what I did but it did not seem to work, did it in a fresh new scene and it works perfectly. I must have done it wrong the firs time.
Thanks anyway
