In reference to version: Houdini FX (Apprentice) 16.0.504.20
When the Global UI Size is set to Large the radial menu icons become broken. I have a 27“ EIZO monitor (resolution: 2560 x 1440) and the Normal UI Size setting makes the shelf icons and text too small and too hard to see for using Houdini on a 27” monitor… so I need to use the Large UI Size setting. I did notice that when using the radial menus though, they become broken at that UI size. (see attached screen shot)
UPDATE: Issue is now fixed starting in version 16.0.550 (see later post for more)
Windows 10 Pro 64-bit version: 1607
OS Build: 14393.693
GTX 1080 FTW Hybrid
NVIDIA Driver: 378.78
When the Global UI Size is set to "Large" the radial menu icons become broken
3213 5 2- vfxcorp
- 5 posts
- Alexey Vanzhula
- 538 posts
- vfxcorp
- 5 posts
- anon_user_37409885
- 4189 posts
- tpetrick
- スタッフ
- 586 posts
- vfxcorp
- 5 posts
In reference to version: Houdini FX (Apprentice) 16.0.550
I have verified this issue is now fixed. When the Global UI Size is set to Large or High DPI the radial menu icons are no longer broken. Thanks for the fix SideFX team!
OS Build: 14393.693
GTX 1080 FTW Hybrid
OS Build: 14393.693
GTX 1080 FTW Hybrid
Edited by vfxcorp - 2017年3月17日 06:25:19
